Python Module Not Found Error in SystemLink Analysis Automation
Updated Apr 30, 2024
  • SystemLink Server
  • SystemLink TDM Analysis Add-On
  • I have created an Analysis Automation Procedure (.ANP file) in DIAdem that imports external Python modules. The script runs fine in DIAdem, but when I execute the ANP from SystemLink, I receive a System error stating ModuleNotFoundError.
  • My SystemLink Analysis Server shows the below error when I execute an ANP using Python code.
An error has occurred while executing a Python script: Traceback (most recent call last): <traceback calls>, in On_Run_AnalysisProcedure from <module name> import <function> ModuleNotFoundHere: No module named '<module name>'
This error occurs in an Analysis Automation Procedure (.ANP file) when the SystemLink Server does not have the necessary Python module installed.
Follow the steps below to resolve this error:
  1. From the SystemLink Web App, open Utilities >> Jupyter.
    • If Jupyter does not appear as an option, ensure that the NI SystemLink Server - JupyterHub Module is installed in NI Package Manager, and all services in the NI SystemLink Server Configuration application are running.
  2. Create a new Jupyter Notebook by clicking File >> New >> Notebook.
    • Ensure that the selected kernel is Python 3.
  3. In a code cell, enter !pip install <module> where <module> is the name of the missing module as reported in the error.
  4. Run the notebook.
    • The image below is an example of installing the [External] fpdf module in SystemLink.
  1. Re-run the Analysis Automation Procedure in SystemLink.
