Opening SystemLink Test Result From Grafana Using Dynamic Links
Updated Apr 12, 2024
  • SystemLink Server
  • SystemLink Test Module
  • SystemLink Jupyter Notebook Add-On
This article demonstrates how to add a dynamic link to a Grafana panel displaying SystemLink Test Insights information. This functionality allows a user to click on a specific cell in a Grafana table and open the corresponding Test Result page in SystemLink.
Prerequisites
Follow the steps below to configure a Grafana panel (such as a table) consisting of test result information to link to specific Test Results in SystemLink.
  1. Ensure that the Grafana panel consists of a column displaying the Result ID for each individual result.
  2. Hover over the Grafana panel and press E on the keyboard to enter Edit Mode.
  3. In the options window to the right-hand side, scroll to find the Data Links option.
  4. Click Add Link.
    • Note: this link will apply to the entire table.
  5. [OPTIONAL] In the pop-up window, enable Open in new tab.
  6. Enter the URL corresponding to the Test Result URL in SystemLink.
    • This URL takes the format of https://<server name>/#testmonitor/testresults/testresult/<result ID> or  http://<server name>/#testmonitor/testresults/testresult/<result ID> depending on whether your server is configured for HTTPS or HTTP.
    • To create a static link (i.e. open the same test result regardless of which table cell is clicked):
      1. In SystemLink, select Test Insights >> Results.
      2. Select the specific result that you wish to link to.
      3. Copy the URL directly into the Grafana Data Link.
    • To create a dynamic link (i.e. open a different test result depending on which table cell is clicked):
      1. The Data Link URL should be <http or https>://<server name>/#testmonitor//testresults/testresult/${__data.fields["<Result IDs Column>"]}
      2. <http or https> depends on whether your sever is configured for HTTPS. To check this, open the NI Web Server Configuration application and review the HTTPS tab.
      3.  <server name> is the name of your SystemLink Server.
      4. <Result IDs Column> is the name of the column in the table that stores the result IDs.
    • The images below show a Grafana table with a column called "Result ID", and a Data Link with the syntax http://<server name>/#testmonitor//testresults/testresult/${__data.fields["Result ID"]}
  1. [OPTIONAL] To hide the "Result ID" column in the table, while maintaining the dynamic link functionality, you must configure an Override. Follow the steps below:
    1. Hover over the panel and press E on the keyboard to enter Edit Mode.
    2. From the Options window on the right-hand side, select the Overrides tab.
    3. Click Add Field Override.
    4. Select Fields with Name. In the drop-down menu, select the name of the column that you wish to hide.
    5. Click Add Override Property. In the drop-down menu, select Hide in Table.
    6. Enable the Hide in Table option.
    7. Below is a picture of the Grafana panel after enabling the Hide in Table option. The "Result ID" column is no longer visible to the user, but the dynamic links still apply.
