Rename, Re-Order or Hide Fields in SystemLink™ Grafana Dashboard
Updated Oct 23, 2026
  • SystemLink Server
  • SystemLink Jupyter Notebook Add-On
  • SystemLink
  • SystemLink Base
  • SystemLink Full
  • SystemLink Professional
  • SystemLink Enterprise
This article demonstrates how to rename, re-order or hide fields used in a panel on a SystemLink™ Grafana dashboard.
Prerequisites
  • [OPTIONAL] If a Jupyter Notebook is used as a data source, The SystemLink Server PC must have the NI SystemLink Server - JupyterHub Module installed.
  • Grafana must be installed on the server PC. Refer to [External] GitHub: NI Grafana Plugins for instructions.
Note: This article was originally written for SystemLink Server, but the overall process will also work in SystemLink Base / Full /Professional / Enterprise, and in those versions the Jupyter Module and Grafana always install automatically.
On a new or existing Grafana dashboard, follow the steps below to organize the fields in a panel:
1. Underneath the dashboard panel, select the Transform data tab.
2. Scroll through the list of transformations and click the Organize fields transformation.
  • You can also search for the desired transformation in the top search bar.
3. In the transformation details:
  • Click the eye icon.PNG icon to hide a field.
  • Enter a new name in the text box to rename a field.
  • Click and hold the Drag icon.PNG icon to drag fields and change the order in which they appear.
4. The panel will automatically update to reflect these changes.
