Programmatically Assign Y Axis in DIAdem 2D Axis System
Updated Feb 13, 2025
  • DIAdem
This article describes how to configure the Y axis for each curve on a DIAdem 2D Axis System that consists of multiple Y axes. The solution is implemented by setting the YAxisReference property of a 2DCurve object.
The TDM data file, DIAdem Report layout (.TDR) and scripts referenced throughout this article are attached for reference.
Follow the steps below to programmatically assign the Y axis for each individual curve:
  1. Launch DIAdem and select the SCRIPT panel.
  2. Click File >> New to create a new script.
    • Select either Visual Basic (VB) or Python script. This article provides an example for each programming language.
  3. Save the script.
  4. In the new script, enter the below lines to clear the Data Portal and load your data file.
    • Change the file name and path for your data file accordingly. The code below assumes that the file is saved in the same folder as the script.
If using Python:
# Load data file and report layout
dd.Data.Root.Clear()
dd.DataFileLoad(dd.CurrentScriptPath + "Example Data.TDM", "TDM", "Load|ChnXYRelation")
If using VBScript:
' Define variables
Dim oMy2DAxisSystem, oMyPosition, oMyAxis, i, oMyCurve
' Load data file and report layout
Data.Root.Clear()
Call DataFileLoad(CurrentScriptPath + "Example Data.TDM", "TDM", "Load|ChnXYRelation")
  1. Use the Report.NewLayout() function to create a new report layout.
If using Python:
# Create a new report
dd.Report.NewLayout()
If using VBScript:
' Create a new report
Call Report.NewLayout()
  1. Using the below code, create a 2D Axis System on the report and position it centered on the page.
If using Python:
# Add a 2D axis system with 2 Y axes
oMy2DAxisSystem = dd.Report.ActiveSheet.Objects.Add(dd.eReportObject2DAxisSystem,"My2DAxisSystem")
oMyPosition = oMy2DAxisSystem.Position.ByCoordinate
oMyPosition.X1 = 20
oMyPosition.Y1 = 20
oMyPosition.X2 = 80
oMyPosition.Y2 = 80
If using VBScript:
' Add a 2D axis system with 2 Y axes
Set oMy2DAxisSystem = Report.ActiveSheet.Objects.Add(eReportObject2DAxisSystem,"My2DAxisSystem")
Set oMyPosition = oMy2DAxisSystem.Position.ByCoordinate
oMyPosition.X1 = 20
oMyPosition.Y1 = 20
oMyPosition.X2 = 80
oMyPosition.Y2 = 80
  1. Using the YAxisList property, add a second Y axis to the 2D Axis System.
If using Python:
oMyAxis = oMy2DAxisSystem.YAxisList.Add("SecondAxis")
If using VBScript:
Set oMyAxis = oMy2DAxisSystem.YAxisList.Add("SecondAxis")
  1. For each channel that should be plotted on the 2D Axis System, create a 2DCurve object and add it to the 2D Axis System.
    • The example code below uses a For Loop to iterate through channels in the Data Portal.
If using Python:
# Using a For Loop, plot 4 channels on the 2D axis system
for i in range(dd.Data.Root.ChannelGroups(1).Channels.Count-1):
    # Add the curve to the graph
    oMyCurve = oMy2DAxisSystem.Curves2D.Add(dd.e2DShapeLine, "Data" + str(i+1))
    oMyCurve.Shape.XChannel.Reference = "Example/Time" # Set X axis as Time channel
    oMyCurve.Shape.YChannel.Reference = "Example/" + dd.Data.Root.ChannelGroups("Example").Channels.Item(i+2).Name
If using VBScript:
' Using a For Loop, set the Y axis for each individual curve
For i = 0 to (Data.Root.ChannelGroups(1).Channels.Count - 2)
    ' Add the curve to the graph
    Set oMyCurve = oMy2DAxisSystem.Curves2D.Add(e2DShapeLine, "Data" + Str(i+1))
    oMyCurve.Shape.XChannel.Reference = "Example/Time" ' Set X axis as Time channel
    oMyCurve.Shape.YChannel.Reference = "Example/" + Data.Root.ChannelGroups("Example").Channels.Item(i+2).Name
Next
  1. Set the YAxisReference property for each of the curves added to the 2D Axis System.
    • The example code below uses a For Loop to iterate through each curve.
    • For each odd iteration, the curve is assigned the first Y axis.
    • For each even iteration, the curve is assigned the second Y axis.
If using Python:
# Using a For Loop, set the Y axis for each individual curve
for i in range (1,oMy2DAxisSystem.Curves2D.Count+1):
    oMyCurve = oMy2DAxisSystem.Curves2D.Item(i)
    # Check if channel is even or odd
    if (i) % 2 == 0:
        # Even channel - plot against Y AXIS 2
        oMyCurve.YAxisReference = 2
    else:
        # Odd channel - plor against Y AXIS 1
        oMyCurve.YAxisReference = 1
If using VBScript:
For i = 1 to oMy2DAxisSystem.Curves2D.Count
  Set oMyCurve = oMy2DAxisSystem.Curves2D.Item(i)
  ' Check if channel is even or odd
    If i mod 2 = 0 Then
        ' Even channel - plot against Y AXIS 2
    Else
        ' Odd channel - plor against Y AXIS 1
    End if
Next
  1. Call the Report.Refresh() function to view changes on the REPORT panel.
If using Python:
# Refresh report
dd.Report.Refresh()
If using VBScript:
' Refresh report
Call Report.Refresh()
When the completed script is executed, the REPORT panel will refresh to show a 2D Axis System with 2 Y axes and 4 curves, as shown below.
Each curve alternates between the 2 Y axes, as shown below:
