Error 401 When Using SystemLink HTTP API in a Web App
Updated Aug 9, 2024
  • SystemLink Server
  • G Web Development Software
  • I am creating a web VI in G Web Development Software. Whenever I try to use the SystemLink HTTP API, I receive status code 401. What causes this?
  • Whenever I make a HTTP request to my SystemLink Server from a VI, the HTTP response body is the HTML of the webpage. Why isn't the request working properly?
This error occurs because of one or both of the below reasons:
  1. The HTTP request does not include the x-ni-api-key header.
  2. There is not an existing valid API key.
SystemLink uses API keys to automate access to the SystemLink API from an external application like a web VI. To resolve this issue, you must:
  1. Create a Policy. This defines an action, resource and workspace for a specific user.
  2. Create an API Key based on the Policy.
  3. Add the x-ni-api-key header with the new API key as the value to your web VI making HTTP requests.
Refer to Using API Key in SystemLink HTTP API for instructions.
