Getting ni-systemlink-message-broker Error When Installing NI Software
Updated Aug 10, 2026
  • SystemLink
  • Package Manager
I am getting the following error when I attempt to install NI software. How should I resolve this issue?
An error occurred while installing a package: ni-systemlink-message-broker (21.1.0.49688-0+f536)
Additional error information:
An error occurred while installing the MSI at 'nisystemlink_message_brokeri.msi'.
This issue is related to problems with updating the existing RabbitMQ installation. There are various approaches to resolve this error.
  • If it is present, remove the Erlang entry from the Windows Registry Editor by following the steps below:
  1. In the Windows Start Menu, search for "regedit".
  2. Right-click Registry Editor and select Run as administrator.
  3. Go to Computer>>HKEY_LOCAL_MACHINE>>SOFTWARE>>Ericsson>>Erlang folder.
  4. Right-click Erlang and select Delete.
  • Deleting the RabbtMQ database by doing the step below:
Move the contents of the folder C:\ProgramData\National Instruments\Skyline\RabbitMQ\db\ to a different location.
  • Unselect one specific additional item during the installation if it is not required by your applications:
During the installation process please untick the NI Web Server Development Support for LabVIEW [version] [bitness] box in the Additional Items you may wish to install window.
If the error persists after following these steps, Generating and Locating NI Package Manager Error Logs and contact NI support.
