NI Package Manager Error: An Error Occurred While Getting the List Of Installed Packages
Updated Apr 8, 2021
  • Package Manager
I am trying to install NI Package Manager in my system using the installer downloaded from NI website but I get the below error. Due to this I cannot install any other software or driver.
An error occurred while getting the list of installed packages.
Additional error information:
There was a problem with calling to the database of installed packages (SQL function call 'sqlite3_prepare_v2' returned error code 1 with error message 'no such table: InstalledPackage'). Note: In order to perform the current operation, you might need to run nipkg.exe as Administrator.
This error is caused if your system earlier had NI Package Manager which was not un-installed properly. So certain temporary files are interfering with the NI Package Manager installation. To resolve this issue delete the 'NI Package Manager' folder located at C:\ProgramData\National Instruments. Once deleted, re-run the installer as an administrator and you should be able to proceed with the installation normally.
