Creating an Account for the NI LabVIEW FPGA Compile Cloud Service
Updated May 6, 2026
  • LabVIEW FPGA Module
  • LabVIEW FPGA Compile Cloud Service
I want to use the NI LabVIEW FPGA Compile Cloud Service , what are the steps to create an account for this service?
Note: The LabVIEW FPGA Cloud Compile Service will be discontinued on October 30, 2026. Please migrate to the LabVIEW FPGA Compile Farm Toolkit for intense compilation needs or use local compilation.
Follow the steps below to create an account for the Compile Cloud  Service:
  1. (You can skip this step if you already have account) Create an account on ni.com with the email address that you wish to use for the Cloud Compile Server.
  2. Make sure that your account has active service benefits. If you don't have service benefits, but you have a license/serial number that has service associated with it, then follow steps 3-5 to register your serial number.
  3. Locate the LabVIEW license and the belonging serial number (If you need help finding it please follow this KB article: Serial Number or Service ID for NI Software
  4. Copy the serial number.
  5. Go to ni.com/register and register your serial number.
  6. Go to The NI Cloud Compile Signup Page
  7. Enter the same email address, which you use on ni.com, select I have active service contract
  8. Click Get Started
  9. Activate the account with the code from the confirmation email, what the site automatically sends you.
  10. Go to the NI Cloud Portal
  11. Log in with your account
  12. Under Product Activation tab verify that you have your service activated.
