The most direct way to determine which software is and isn't activated is to open up NI License Manager on your local machine and confirm that the icons in your Local Licenses tab are what you expect. You can activate and deactivate software from this page by right-clicking on any license entry.
Activation codes are generated based upon the combination of product, serial number, version, and computer ID, and will only work for the specified system.
If you run into trouble using an activation code, ensure the correct information was entered into the licensing wizard. Verify:
- Computer ID  - Each computer generates a unique Computer ID. Activation codes from another computer will not work.
- Product - For example, LabVIEW and LabVIEW Remote Panels are not the same.
- Software Version - For example, LabVIEW 2012 Professional, LabVIEW 2012 Full, LabVIEW 2012 Professional SP1 will all require different activation codes.
- Serial Number - Ensure that the serial number you enter is for the exact product you are activating.
- If you found your serial number on packaging associated with a hardware purchase (DAQ, RIO, PXI, etc.) it is likely that it is the hardware serial number for those products and will not activate the software. Check the order and packaging associated with your software purchase for any additional serial numbers.
- License File - If your serial number is part of a network license, you may require a new license file, please contact NI Support in this case.
- NI License Manager 3.7 or above installed - There are known issues with activation codes and serial numbers not working in versions of NI License Manager before 3.7. You can find NI License Manager in Windows by navigating to Start»All Programs»National Instruments»NI License Manager. The current version is displayed at the top of the NI License Manager window.
If your activation still fails and you have verified your information, you can contact NI.
