Client Partially Connected to SystemLink Server Cannot Publish Data
Updated Oct 16, 2025
  • SystemLink Server
  • SystemLink Client
  • My SystemLink server’s system table shows the client as “Partially Connected”, the client can connect to the server but it cannot publish data (tags, files, results)
  • My SystemLink Client software shows the Partially Connected status and it does not change to Connected, even after waiting for hours.
The first step is to ensure that the "Enable AMQP client access (less secure)" option is unchecked in the Security category of the NI SystemLink Server Configuration utility. AMQP was the communication method used in earlier versions of SystemLink, and the option was retained for compatibility. However, there are reports of client systems with SystemLink Client 2022 Q1 and more recent versions showing as Partially Connected due to this option.
If that option is already unchecked, it means that the client is connected and able to run jobs from the server but the actual HTTP(S) connection info that got pushed from the server side to the client is in a bad state. Try the following suggestions:
  • Check the configured hostname field in the SystemLink Client dialog. The best practice is to always use the (full) preferred hostname.
  • The preferred hostname must be reachable/resolvable by the client.
    • You can check this in DOS with ping hostname.
    • Use the same hostname as entered in the NI Web Server Configuration dialog. This can be found in the Remote tab, in the “Preferred host name” field.
  • Check the web certificate shown on the server’s NI Web Server Configuration dialog. This is only relevant for HTTPS communication, if you are using HTTP skip this suggestion.
    • Go to the “HTTPS” tab, then click the “View certificate” button, and verify that:
      • The “Issued to” field is the same hostname used on the client system.
      • The “Valid from” field shows the certificate has not expired.
  • In the SystemLink Server Configuration dialog, under "SystemsManagement", see if the "Override options for HTTP communication" checkbox is selected.  This should only rarely be used, and if you have an old certificate path here and the checkbox selected, the server will repeatedly install the old certificate onto the clients…
  • Check the HTTP(S) connection info stored on the client system:
    • For a Windows client it can be found in C:\ProgramData\National Instruments\Skyline\HttpConfigurations\http_master.json
    • For a Linux Real-time client it can be found in /etc/natinst/niskyline/HttpConfigurations/http_master.json
    • The “Uri” field should match the address/port of the server.
    • The "ApiKey" should be a valid string and not null.
    • Test the HTTP(S) info using a DOS curl command (simulating a GET web request), by running the following command, replacing the string placeholders:
      • curl -i ${Uri}/niauth/v1/auth -H "Content-Type: application/json" -H x-ni-api-key:${ApiKey}
        • This either returns a valid JSON string or throws an error:
          • A valid JSON string means that the issue is the reporting client state.
            • The client state should be fixed in the next 30 minutes because SystemLink runs a beacon to update the state.
            • Restarting “NI Salt-Minion” service forces state update.
          • An error means the HTTP(S) info is the problem; unauthorized error points to a stale ApiKey, unreachable error points to failed Uri path.
            To regenerate these values on the server and push new data to the client:
            • Move the client system to a new Workspace.
            • Remove / Re-approve SystemLink client (this loses client info, including alias, jobs and properties).
    • If the http_master.json file cannot be found in the client, make sure the server has enough resources and is not being constrained by CPU or RAM usage. A lack of resources can cause the server to not initiate the refresh job that triggers the creation of this configuration file in the client.
  • If none of this helps, try restarting the SystemLink service called "SystemsManagement" to purge any outdated client information cached in RAM.  You can do this by rebooting the SystemLink Server computer, by restarting all the SystemLink Server services in the NI SystemLink Server Configuration dialog, or by restarting only the "SystemsManagement" service by using a DOS console on the SystemLink Server computer, described at the below link:
