SystemLink identifies the clients based on the Minion ID which is expected to be unique, if there are multiple machines with the same Minion ID the server can treat them all as being a single client. The Minion ID is specific for every computer based on the product name, serial number and MAC address.
In order for SystemLink Client to update its Minion ID is it advised to:
1. Navigate to this path C:\Program Files\National Instruments\Shared\salt-minion in the client machine.
2. Right-click the salt-minion-cleanup.bat file and select Run as administrator.
You can also open a Command Prompt window with administrator privileges, and enter:
"C:\Program Files\National Instruments\Shared\salt-minion\salt-minion-cleanup.bat"
3. Reattempt the connection to the SytemLink server from the SystemLink Client.
