Adding Custom Information to Test Results Uploaded to SystemLink Server
Updated May 1, 2025
  • SystemLink Test Module
  • SystemLink
  • TestStand
I would like to add additional information to my test results displayed in the SystemLink Web Application>>Test Insights>>Results or a different status not just Done, Passed or Failed.
You can achieve this by configuring the test results from TestStand after integrating Test Monitor with TestStand. There are different options available:
1. From TestStand, fill in the Additional Results property with the information you want to add:
2. In SystemLink>>Test Insights>> Results, click the sequence you want to check, and navigate to the step you added the Additional Results property:
3. Double-click the step of the sequence and expand the All Data menu, you'll see the information added there:
  • Another alternative is to add keywords or properties to your sequence, you can use these keywords to filter results later on if needed:
1. In TestStand you can add keywords or properties in the SystemLink category of the Insertion Palette:
2. In SystemLink you'll be able to see the keyword added to the results:
