Change Predefined Settings When Creating a New DIAdem Report
Updated Oct 26, 2022
  • DIAdem
This article goes through the steps to modify the predefined settings of a DIAdem report such as font size, font colors, chart grid color, line width, etc.
You can modify the default settings for a specific report type by following these steps. In this case, a 2D Axis System is used as an example.
1. Select the DIAdem REPORT panel.
2. Click the 2D Axis Systems group bar.
3. Right-click a button in the function group.
4. Select Predefined Setting... from the shortcut menu.
5. Open the Axis Parameters tab and then you can change the properties such as font size by selecting Numbers, Labels, or other categories on the left panel.
6. Once you have selected the desired setting click on Change.
Once you do this and create a new axis system in the worksheet, the created axis system should have the new settings. Please note that the same process is applied to other types of reports.
