How to Create a Master Layout in DIAdem Report
Updated Nov 1, 2023
  • DIAdem
How can I create a Master Layout in DIAdem and set it as default?
  • Click on Report and if you have no blank paper click on New Layout
  • Create a new Master Layout
  • Choose between LandScape and Portrait Master
  • Edit your Sheet and save it as a *.TDRM file
  • Create a new Layout like described in the first step
  • Go to Layout Parameters and add the master layout to your Report File.
  • Save your Report Layout
If you also would like to set this Master Layout to the default DIAdem Layout follow these steps:
  • Go to the DIAdem Settings
  • Choose your Layout as the Default file in the REPORT section
  • Press OK, close DIAdem and save the settings to the Desktop.DDD prompted in the pop-up window.
