Converting Units in a Data Preparation Procedure
Updated Jun 1, 2023
  • DIAdem
  • SystemLink
This article demonstrates how to use unit conversion when making a Data Preparation Procedure (*.DPP file) in DIAdem.
This feature is useful for standardizing units across multiple data files that may be created from multiple sources or operators.
For demonstration purposes, this example uses a TDMS data file and converts kV to V. Find the finalized .DPP and test TDMS file attached.
Follow the steps below to configure unit conversion:
1. Launch DIAdem.
2. Clear the Data Portal and load your data file from the NAVIGATOR panel.
  • This example loads a file called "Test Data.tdms".
3. Navigate to the SCRIPT tab and click Settings >> SystemLink TDM >> Data Preparation Procedure... from the top toolbar.
4. In the pop-up window, click New Data Preparation Procedure.
  • If prompted to save changes, click No.
  • Specify a Name, Description and Author. This example creates a file called "Test Data Preparation Procedure.DPP".
  • Click OK.
5. From the Replace Identifiers tab, place a check in Harmonize property identifiers and click the Edit... button.
6. In the pop-up window, select the Channel tab.​​​​​​
7. Click Add DataPlugin Mapping.
  • In the pop-up window, select the DataPlugin that matches your data file. This example uses the TDMS DataPlugin.
  • Click OK.
8. In the new pop-up window, set the Standardized Identifier to unit_string and Original Identifier to the name of the property that contains your units.
  • For example, the image below shows that the channel called "Sine Wave" has a Custom Property called "Units" with a value of kV. Therefore, the Original Identifier should be Units.
  • Click OK.
  • Click Close.
9. Select the Convert Units tab.
10. Place a checkmark in the Unit conversion box and click Edit...
11. In the pop-up window under the Unit Sets tab, enable the Unit Set you wish to use.
  • This example uses SI Units.
12. Select the Quantities tab.
  • Scroll through the list of quantities and select the quantity that you're interested in.
  • This example uses Electric potential.
13. Select the Units tab.
  • Ensure that the unit you wish to convert is listed under the Symbol column. This example converts kV to V, which is already a recognised symbol.
  • If the symbol you wish to convert is not listed, click the New Entry (plus symbol) button.
  • Ensure that your standardized unit is set to Default. Since this example is standardizing to V, this is checked as Default.
  • Click Close.
14. To test the Data Preparation Procedure, click Debug Data Preparation Procedure.
  • If prompted to save, click OK.
  • In the file selection dialog, select the data file you wish to test with.
  • When the simulation completes, click OK to dismiss the dialog.
  • In the Data Portal, check the Base Properties of the channel and observe that the unit conversion has taken place.
Once complete, the .DPP file can be uploaded to a SystemLink Data Preprocessor Instance. Refer to SystemLink Documentation: Creating a Data Preprocessor Instance and SystemLink Documentation: Configuring a Data Preprocessor Instance for instructions.
