Astronics Ballard ARINC 429 or MIL-STD-1553 PXIe Card Not Recognized in NI Linux RT
Updated Feb 24, 2026
  • Ballard MIL-STD-1553
  • Ballard ARINC 429
I have an NI Linux RT PXI controller and chassis with an ARINC 429 or MIL-STD-1553 installed in it.
I can see my PXI system in NI Measurement & Automation Explorer (MAX) but my ARINC 429 or MIL-STF-1553 cards do not appear/are not recognized. All the other modules are recognized correctly in MAX.
How to fix this issue?
This is expected behaviour. Please ensure you have connected the Remote Controller to Internet.  If you are using an Offline Linux RT controller, please refer to this Installing Software to Offline NI Linux Real-Time Targets.
Unlike with Windows or Phar Lap, the Astronics Ballard ARINC 429 or MIL-STD-1553 PXIe cards will not appear in MAX.
Support is added to your Linux system by:
  1. Right-Clicking Software under your PXIe system and going to Advanced > Manage Feeds
  1. Enter your username and password if prompted
  2. Find ni-third-party in the list of feeds and click the edit icon in the Actions column
  1. Tick the Enabled box for the feed
  1. Click Update and then Close
  2. Now Right-click on Software under your PXI system and select Add/Remove Software
  3. With third-party feeds now enabled, you will now see an option to add Astronics Ballard Avionics Driver. Tick this option and click Review changes
  4. After a few seconds, click Continue
  5. When the installation is complete you will have successfully added driver support for the Astronics Ballard cards.
Note, even with the driver installed, the Astronics Ballard cards will still not show up in NI MAX.
You can check if the card works correctly by using one of the examples for the card.
For example, using an Astronics Ballard Arinc 429 card with LabVIEW 2021:
C:\Program Files (x86)\National Instruments\LabVIEW 2021\examples\Astronics Ballard Technology\LabVIEW RT\Card Test
ARINC 429 or MIL-STD-1553 modules can be addressed by either Card Number and Core Number or PXI Slot Number and Core Number. The Initialize VI is polymorphic, so you can select how to address the module.
