Installing Software to Offline NI Linux Real-Time Targets
Updated Mar 10, 2026
  • PXI Controller
  • CompactRIO Controller
  • NI Linux Real-Time Offline Installation Support
  • NI Linux RT System Image
This tutorial covers the process for installing software on an offline NI Linux Real-Time target using the NI Linux Real-Time Offline Installation Support bundle.
The offline support bundle contains a package repository of all the packages located on the NI website feed specific to the user-specified release version. The software package repository installer and offline installation support allows the installation of software packages on Linux Real-Time targets when the target and host PC are in a secure environment that cannot access NI website.
The offline support bundle contains all packages available on NI website and uses Linux’s package-based system to install software to the target. The support files allow the host PC to act as a server from which the target retrieves its packages.
Install NI Software
Note:
  1. Install the latest version of NI Package Manager (PM) on the host PC.
  2. Launch NIPM.
  3. Search for and install System Configuration and NI Linux Real-Time Offline Installation Support. The version of the NI Linux Real-Time Offline Installation Support must be matching with the NI Linux RT Base System Image installed on the target.
  4. After the package repository and offline installation support successfully installs to the host PC, close the success dialog.
Install Third Party Feed
If third-party drivers are being used, follow these steps to download and install the files to the host PC. Since the target cannot access the internet to fetch the packages, the third-party drivers feed content must be installed in a location on the host PC that NI Measurement and Automation Explorer (MAX) uses to serve the packages to the target. If third-party drivers are not being used, skip to the next section.
  1. Open http://download.ni.com/ni-linux-rt/feeds/2020/ni-third-party in a browser. Change the feed version if necessary.
  2. Download all the files on the feed and install them in a new folder inside C:\Program Files\National Instruments\RT Feeds\20.x\. The new folder must not contain any spaces. For example, C:\Program Files\National Instruments\RT Feeds\20.0\third-party-driver-feed.
Note: Some web browsers add a .txt extension to files that have no extensions. Make sure the copied file names match the names on the feed, especially the extension-less "Packages” file.
Image1.jfif
Install Software on Linux Real-Time Target
  1. Launch NI MAX.
  2. Expand Remote Systems and navigate to the desired target.
  3. Expand the target. Right click and select Add/Remove Software.
  4. If using a new/formatted device, select the Base System Image to be used on the target. The available versions can be accessed by clicking the gear icon on the left-hand side. Once the selection has been made, click OK.
    A base system image contains the operating system and components to manage NI software through feeds located on NI website or a user-specified location.
Note: The most recent base system image is selected by default. In case there is no requirement of a base system image to manage the software on the target, it is possible to install software set from the Legacy Installation section only if LabVIEW Real-Time is installed on the host PC. The Legacy Installation method does not exist for PXI Linux RT target.
  1. It may be required to format the target after the selection of a new base system image. If formatting is required, click Format when prompted.
  2. Once formatted, select the programming environment to use on the target and click Next.
  3. Select Allow the target to retrieve packages from feeds hosted on this computer and click OK. It might be necessary to select another port if the preselected port is unavailable. The look of the page will be different if the host PC is online or offline:
    • Online Host PC
    • Offline Host PC
  4. Click Yes to allow the NI RT Feed Server to open a port in the firewall.
  5. Choose the packages to be installed on the target and click Review changes. Packages are preselected based on the target's base system image and programming environment.
  6. Review the packages that have been selected for installation and click Continue to retrieve the packages from the host PC and install them onto the target.
  7. After installation is complete, click Close to dismiss the success dialog.
Install NI Software from a USB Drive on the RT Target
If the Host PC has firewall restrictions that make any feeds inaccessible to the NI Linux RT target. it is possible to store the repositories on a drive attached to the RT target. This is typically a USB drive plugged into the PXI or cRIO controller.
  1. Download the version of base image you wish to install: NI Linux Real-Time Offline Installation Support. and install on a host (Windows) PC.
    • The version should match the installed Base System Image version installed on the RT target, or the one you wish to install.
    • If you want to ensure the RT target is a 'clean install' consider restoring the factory defaults: Restore NI Linux RT Target to Factory Default Configuration.
      • Note: After restoring the target, you will need to install a Base System Image. Otherwise, some files from step 5 will not appear.
  2. Copy all the files located in C:\Program Files\National Instruments\RT Feeds\XX.Y.Z to a USB drive. Where XX.Y.Z is the Base System Image version you wish to install on the RT target.
    • There are two important considerations:
      • Each quaterly release corresponds to a 'XX.X' version.
        • Q1 = XX.1
        • Q2 = XX.3
        • Q3 = XX.5
        • Q4 = XX.8
      • The directory is considerable large (approx. 32 GB). Therefore, you can expect a delay when copying the files from the local path to the USB drive.
  3. Access the Shell of the target. Through steps 3 to 5, it is highly recommended to use [EXTERNAL] MobaXterm, as it includes an intuitive UI that allows you to easily find and comment the files, as described below.
  4. Open the files listed below with a text editor and comment out each line with a # in each file.
  5. The vi text editor is installed by default. Execute vi /path/filename. To enter the edit mode in vi, press [i]:
    • /etc/opkg/ni-third-party.conf
    • /etc/opkg/ni-software.conf
    • /etc/opkg/NI-dist.conf
    • /etc/opkg/base-feeds.conf
  6. After completing editing, press [ESC] to enter the command mode and type :wq to write the changes and quit. To avoid writing the changes, enter :q!
  7. Connect the USB drive to the target and locate its mount path by typing lsblk in the shell.
  8. Run the following command to generate the local feeds:
    • find /USBMountPath -name 'Packages.gz' -exec dirname {} \; | awk '{print "src/gz local" NR " file://" $0}' > /etc/opkg/local.USBfeeds.conf
    • Replace /USBMountPath with the actual path. In this case, it is /media/sda1
  9. Wait until the command finishes its execution.
  10. From the RT target command prompt run opkg update and all the feeds should point to the local drive.
You should now be able to install software with NI MAX as long as the USB drive is connected and is mounted to the target.
The installed packages now appear in the target's Software section.
An example of output from opkg update after configuring repositories on a drive local to the RT target:
admin@NI-cRIO-9047:~# opkg update
Downloading file:///media/sdb1/arm/main-all/Packages.gz.
Downloading file:///media/sdb1/arm/main-all/Packages.asc.
Updated source 'local1'.
Downloading file:///media/sdb1/arm/main-cortexa9-vfpv3/Packages.gz.
Downloading file:///media/sdb1/arm/main-cortexa9-vfpv3/Packages.asc.
Updated source 'local2'.
Downloading file:///media/sdb1/arm/main-xilinx-zynq/Packages.gz.
Downloading file:///media/sdb1/arm/main-xilinx-zynq/Packages.asc.
Updated source 'local3'.
Downloading file:///media/sdb1/arm/salt-all/Packages.gz.
Downloading file:///media/sdb1/arm/salt-all/Packages.asc.
Updated source 'local4'.
Downloading file:///media/sdb1/arm/salt-cortexa9-vfpv3/Packages.gz.
Downloading file:///media/sdb1/arm/salt-cortexa9-vfpv3/Packages.asc.
Updated source 'local5'.
Downloading file:///media/sdb1/arm/salt-xilinx-zynq/Packages.gz.
Downloading file:///media/sdb1/arm/salt-xilinx-zynq/Packages.asc.
Updated source 'local6'.
Downloading file:///media/sdb1/ni/Packages.gz.
Downloading file:///media/sdb1/ni/Packages.asc.
Updated source 'local7'.
Downloading file:///media/sdb1/ni-labview-2023/Packages.gz.
Downloading file:///media/sdb1/ni-labview-2023/Packages.asc.
Updated source 'local8'.
Downloading file:///media/sdb1/ni-labview-2024/Packages.gz.
Downloading file:///media/sdb1/ni-labview-2024/Packages.asc.
Updated source 'local9'.
Downloading file:///media/sdb1/ni-labview-2025/Packages.gz.
Downloading file:///media/sdb1/ni-labview-2025/Packages.asc.
Updated source 'local10'.
Downloading file:///media/sdb1/x64/main-all/Packages.gz.
Downloading file:///media/sdb1/x64/main-all/Packages.asc.
Updated source 'local11'.
Downloading file:///media/sdb1/x64/main-core2-64/Packages.gz.
Downloading file:///media/sdb1/x64/main-core2-64/Packages.asc.
Updated source 'local12'.
Downloading file:///media/sdb1/x64/main-x64/Packages.gz.
Downloading file:///media/sdb1/x64/main-x64/Packages.asc.
Updated source 'local13'.
Downloading file:///media/sdb1/x64/salt-all/Packages.gz.
Downloading file:///media/sdb1/x64/salt-all/Packages.asc.
Updated source 'local14'.
Downloading file:///media/sdb1/x64/salt-core2-64/Packages.gz.
Downloading file:///media/sdb1/x64/salt-core2-64/Packages.asc.
Updated source 'local15'.
Downloading file:///media/sdb1/x64/salt-x64/Packages.gz.
Downloading file:///media/sdb1/x64/salt-x64/Packages.asc.
Updated source 'local16'.
