There are no specific LabVIEW VIs that control the Window Services. In order to stop or start a service, the System Exec VI can be used in conjunction with the correct command line call. The command line argument is wired into the Command Line input terminal of the System Exec VI as shown in the figure below.
![](/servlet/rtaImage?eid=ka00Z000001Drve&feoid=00N0Z00000HEWRt&refid=0EM0Z000000RqBR)
For example, to start the NI Variable Engine, type the following in the input string terminal:
net start "NI Variable Engine" Note: Prior to LabVIEW 2012, NI Variable Engine is listed as National Instruments Variable Engine in Windows Services.
