Generating a Package Installation Report from NI Package Manager
Updated Dec 8, 2023
  • Package Manager
I want to obtain a text file report of all the packages installed on my system through NI Package Manager, either for my own documentation or for troubleshooting. How can I generate this report?
This report can be generated using NI Package Manager's command line interface (CLI).
  1. Open a Windows command prompt with administrator privileges: Open the Start Menu, then navigate to Windows Accessories. Right-click Command Prompt and click More » Run as administrator.
  2. Navigate to NI Package Manager's directory using the below command:
cd "C:\Program Files\National Instruments\NI Package Manager"
  1. Run the following command in the same command prompt:
nipkg info-installed > C:\report.txt​​
The report file generated by the above command will be located in the root directory of the C drive as a file named report.txt. The text file generated will contain detailed information about the packages installed on your system.
In the above example, the report file is generated in the user's C drive as report.txt. This path can be changed to other locations or file names as long as a text file is targeted.
