The hardware revision will be included in the device's part number.
Find the part number of the hardware. The part number is typically located on a label attached to the device.
Examine the structure of the part number. It should have a format similar to the following:
XXXXXXY-XXZ
where:
- X represents a number
- Y represents the hardware revision letter
- Z represents a letter
Identify the letter in the "Y" position. This letter indicates the hardware revision.
Example: Part number 157420C-01L corresponds to hardware revision C.
Alternatively, view the hardware revision in NI MAX:
- Open NI MAX.
- Select the device in the configuration tree.
- Locate the Hardware Revision field in the device information pane.
- Review the displayed revision value.
The following example shows the
Hardware Revision field in NI MAX:
