EtherCAT Slaves in LabVIEW are intended to comply with the specifications of the
Ethercat Slave Information Specification document, for that reason any ESI file that complies with this specification should work with LabVIEW.
The only exception is the
ARRAY data type which is currently not supported in LabVIEW. Should you need to operate on arrays, consider using
Raw Data Mode to achieve this operation with speed.
