このコンテンツは設定された言語で表示できません。
You can use this NI-DAQmx and LabVIEW Compatibility Table to quickly compare version support. Note: You cannot have more than one version of NI-DAQmx installed at the same time on the same machine. For more information, please review: Installing Multiple Versions of NI-DAQmx on the Same Machine .Use that compatibility information along with the other information found in these articles to prepare, install and troubleshoot on your system: Upgrading or Downgrading LabVIEW with NI-DAQmx .If you need to use more versions of LabVIEW than a single version of NI-DAQmx can support, one option is to use one or more virtual machines with compatible versions.If you installed another compatible version of LabVIEW and now you are missing NI-DAQmx functions, palettes, or receiving errors, please review the troubleshooting steps in this article: Upgrading or Downgrading LabVIEW with NI-DAQmx .
