I recently installed LabVIEW or updated my NI-DAQmx version. I may already be able to see my DAQ device or module in Windows Device Manager or NI Measurement & Automation Explorer (MAX) under Devices and Interfaces.
I am experiencing one or more of the following problems:
- I am missing certain DAQmx LabVIEW subVI icons do not show up, aren’t visible or don’t appear in my LabVIEW Measurement I/O functions palette.
- DAQmx functions and libraries show up in one version of LabVIEW, but not another. Similarly, they show up 32-bit LabVIEW, but not in 64-bit or vice versa.
- I am getting a broken run arrow or searching for DAQmx subVI’s when opening a VI or trying to run DAQmx calls.
- When I open the Measurement I/O Palette on the block diagram, I do not see the DAQmx VIs as expected.
- I am missing certain NI MAX functionality:
- No Test Panels options when I right-click on my device in NI-MAX
- Find Network NI-DAQmx Devices option is missing when right-clicking Network Devices
- There is no Data Neighborhood folder under My System in NI-MAX
- I do not have have the option to create Virtual Channels in NI-MAX
Why can’t LabVIEW find my DAQmx palette, functions and subVI’s or run my code? Is my installation corrupted or is there a bug in the installer?
