There are a number of software items you need to have installed on your computer in order to use an Ethernet cDAQ as a sync resource in LabVIEW. See the following minimum software versions you will need to use your chassis as a sync resource:
- LabVIEW 2015 SP1 or later
- NI-DAQmx 17.1 or later
- NI-TimeSync 18.1 or later
- For cDAQ-9185 and cDAQ-9189, firmware 18.1 or later
