USB3 or GigE Camera Shows Up as Unknown Device in Device Manager
Updated Apr 10, 2026
  • NI-IMAQdx
Other
  • USB3 Vision Camera
  • GigE Vision Camera
When I look at Windows Device Manager to make sure that the camera (USB3 or GigE) is recognized correctly, the camera shows up as an Unknown Device.
Image result for unknown usb device device manager
When I open NI Measurement and Automation Explorer (MAX), I either do not see my camera or, if I do see my camera, I am unable to obtain images because I receive the error "Camera not found."
These errors are observed when the host PC is having issues or can't communicate with the camera. Try the following steps to fix this issue.
    1. Sometimes, simply unplugging your camera and plugging it back in can allow Windows to correctly identify the camera. If it is still not correctly recognized, you must manually associate the camera with the appropriate IMAQdx Vision driver:
    2. Open Device Manager from the Control Panel in Windows.
    3. Right-click on the Unknown Device and select Update Driver.
    4. Select Browse my computer for driver software.
    5. Select Let me pick from a list of available drivers on my computer.
    6. With Show compatible hardware checked, choose the NI-IMAQdx Vision Device version that matches the version of IMAQdx that you have installed and click Next to install the driver.
      1. After install completes, you should see "Windows has sucessfully updated your driver" and your camera should now show up under NI Vision Acquisition Devices.
      2. The specific name of the driver will depend on the type of camera you are using. If you are using a USB camera, you should see NI-IMAQdx USB3 Vision Device. If you are using a GigE camera, you will see NI-IMAQdx GigE Vision Universal Driver or NI-IMAQdx GigE Vision High Performance Driver.
      3. If no NI-IMAQdx Vision driver shows up in the list, continue with step 7.
If steps 1-6 do not lead to a successful install of a driver, we can point the utility directly to the inf file for the camera.
  1. In the "Select the driver you want to install for this hardware" window, select Have Disk...
  2. In the "Install From Disk" window, select Browse...
  3. Navigate to C:\Program Files (x86)\National Instruments\NI-IMAQdx\Staging\ and then select the folder associated with the appropriate camera type (ex, NI USB Vision or NI GigE Vision). Choose the .inf file within this folder and select Open.
  4. In the Install From Disk window, click OK. You should now see NI-IMAQdx Vision Device in the list of models. Click Next to install the driver for your camera.
The camera should now show up in Device Manager under the NI Vision Acquisition Devices category as NI-IMAQdx Vision Device.
This issue is common with cameras that communicate over USB but are not USB3 Vision Compliant. Make sure your camera is supported by NI by checking the Camera Interfaces Supported by NI Software article.
