How to Use USB-6501 Digital Output Voltage Level Up to 5V
Updated Feb 2, 2024
  • Digital I/O Device
  • Multifunction I/O Device
I want to use USB-6501 a digital output level up to 5V. However, It is just measured as 3.5 V. How I Use USB-6501 Digital Output Voltage Level Up to 5V?
If you want to use a digital output channel level up to 5V, you should set the digital output port as the open collector(open-drain) mode. The digital output port of USB-6501 which is set as active drive(Push-Pull) only generate output voltage up to 3.5V. This configuration are programmable at LabVIEW or NI MAX. Refer to following figures for each case.
  • NI MAX
If you use other digital output modules, please check the digital logic level in the data sheet.
