Choosing Between Line Driver, Open Collector, and Push Pull Encoders for NI Device
Updated Aug 1, 2023
I want to determine the difference between line driver, open collector, and push-pull quadrature encoders and how to tell which type I should use.
For most NI DAQ cards, a Push-Pull quadrature encoder is recommended since Multifunction DAQ card works best when it is constantly driven. The Push-Pull configuration does not float, it is always supplying Vcc or ground, which is why it will work best with a Multifunction DAQ card.
If you are working with an Industrial I/O Card, check the user manual for the best quadrature encoder type.
Line Driver
A line driver is a sourcing output. When in the on state, a line driver will supply Vcc. In the off state, a line driver will float. Because of this, a sinking input is required for proper operation. Please refer to the table below for a simple example of a line driver.
Open Collector
An open collector is a sinking output. In the on state, an open collector will supply a path to ground. When in the off state, an open collector will float. For proper operation, a sourcing input is required. Please refer to the table below for a simple example of an open collector.
Push-Pull
A push-pull output is a combination of a line driver and an open collector. In the off state it will supply a path to ground and in the on state it will supply Vcc. Please refer to the table below for a simple example of a push-pull output.
