Create the Installer
NI Package Builder (available on the NI Package Builder Download Page) can be used to bundle multiple NI product installers into a single package or package installer. Follow these steps to create an installer, which will contain your chosen software and all dependencies.
- Open NI Package Builder and access the Installers and Repositories pane.
- Select New Installer or Repository, then select either:
- New Package Installer to create a package installer that includes NI Package Manager. Users can install packages by double-clicking the Install.exe file, even if NI Package Manager is not pre-installed. Note that this installer contains only a single version of each package.
 - New Local Repository to create a repository that can be consumed by NI Package Manager. A local repository requires the user installing the files in the repository to already have NI Package Manager installed. NI Package Builder currently can only create a new repository and not add to an existing repository.
- Select Add Packages to add packages to the repository or package installer.
- For packages local to the solution, select the checkboxes for the packages to include.
 - For external packages, select Show Additional Sources. NI Package Builder can add external packages that have been installed to your PC, as shown in Installed Packages, or downloaded to your PC as a package installer, shown in Installer Products.
- After adding the packages, they will be visible under the Installer. If needed change Include recommended and suggested packages (only available for local/installed packages) and modify the Installation Behavior as preferred.
- If this is a new solution, then select File»Save Solution to save the solution. This is necessary because build outputs are placed in subdirectories relative to the solution, by default.
 - Build the installer or repository. Use the Errors and Warnings pane to address errors as needed.
- If the installer or repository requires solution packages to be built for the first time or built again, select Build»Build Solution in the application-wide toolbar.
 - If the installer or repository requires solution packages that have already been successfully built with your most recent version of the files, then select Build»Build Installers and Repositories in the application-wide toolbar to skip rebuilding the packages.
The installer directory NI Package Builder creates can now be moved to another computer or a network drive for deployment.
Run the Installer
To run the installer non-interactively without any user input use the following in the command prompt, or in a batch file (see Automating an Online or Offline Installer).
start /wait Install.exe --passive --accept-eulas --prevent-reboot
With NIPM 20.7 or later, you can use the following command instead to run the installer fully silently.
start /wait Install.exe --quiet --accept-eulas --prevent-reboot
If you would also like the installer to point clients to a Volume License Server see How Can I Build a Volume License Installer Using Multiple NI Installers?. If you want to mix 2019 software with pre-2019 software, you will need to create two separate installers, wrap your older installers in a package.
