Batch Installer Builder enables you build installers that contain NI software from any number of NI products or updates. By adding NI installers to the Batch Installer Builder source library, you can create build specifications that combine your installers into custom bundles that meet your needs. This Knowledge Base article takes you through the steps of creating a custom installer.
Important Note: The NI Batch Installer Builder is intended for software released before 2019. If you are creating new installers, use NI Package Builder.
