Modify Excel Chart Series Name Using ActiveX in LabVIEW
Updated Jul 11, 2019
Other
Microsoft Excel
I am using ActiveX to to create charts in Excel, how do I change my plot's "Series Name" within LabVIEW?
You must make use of several of the ActiveX property nodes in series for Excel to access the Series.Name property. Please see the attached VI and the screenshot below for one example on how this can be done.
You can also use Excel Function Syntax to specify a cell data for naming the Series name.
The example below extract the string in Cell A16 of the active sheet and writes that value as the Series name.
