Solution:
NI recommends against using USB hubs, as hub specifications vary by design and manufacturer and can introduce shared power and bandwidth limitations. USB DAQ devices connected through a hub may experience intermittent connectivity or performance issues due to these constraints. Even if the device appears to operate normally, the hub may drop data packets or exhibit unstable behavior, which is outside the control of the DAQ device.
Power Limitations
There are two kinds of USB hubs: bus-powered hubs and self-powered hubs. Bus-powered hubs receive all of their operational power from the USB bus, while self-powered hubs receive their operational power from an external power supply.
Data acquisition devices (DAQs) can be used with bus-powered hubs, but in most cases this will require a power supply to power the hub's downstream ports. The power available to USB devices connected to a bus-powered hub decreases as more devices are connected. This decreased power level can become insufficient to power and operate some of NI's USB devices. In this case, the operating system will report an error, saying that there is insufficient power to run the device.
A functional supply can be selected as specified by the hub's vendor. This requires that the device support a self-powered configuration where an external supply can be provided.
Bandwidth Limitations
A USB hub shares it's maximum bandwidth across each connected device. Even if a connected device is asleep or inactive, some of the bandwidth will still be reserved for that device.
For example:
Consider a USB hub using USB 2.0 (with a maximum data transfer rate of 30-40Mbps). If there are two peripheral devices connected to this hub and actively transferring data, each device may only transfer at a rate of 15Mbps. If one of the devices is asleep, the remaining device still does not have access to the full 30Mbps.
Therefore, it is important to consider if your USB hub is capable of achieving your desired data throughput while other devices are connected.
