CompactRIO C Series Modules Not Showing in NI MAX With Non-DAQmx RT Targets
Updated Aug 1, 2025
  • CompactRIO Controller
  • C Series Digital Module
  • NI-9147
  • Ethernet Device
I am able to see my CompactRIO (cRIO) under Remote Systems in NI Measurement & Automation Explorer (MAX).  However, when I expand Devices and Interfaces under the cRIO, I can't see my C Series I/O modules. Why can't I see the C Series modules in MAX?
Only cRIO controllers with NI-DAQ™mx capabilities (cRIO-904x and cRIO-905x) and cDAQ systems provide access to C Series modules through NI MAX. If you are using a cRIO-904x or cRIO-905x, please ensure that NI-DAQmx is installed on your system. If NI-DAQmx is not installed, follow the instructions in the Getting Started with CompactRIO Hardware and LabVIEW tutorial. Note: If you experience problems installing NI-DAQmx, you may need to reformat your cRIO device and reinstall the software.
If you are using any other CompactRIO controller, C Series Modules will not be listed in NI MAX. Instead, the two potential options you have for detecting the Modules are listed below:
  • You can create a LabVIEW project and detect the modules as explained in Detect Your CompactRIO System using LabVIEW article.
  • You can use NI Distributed System Manager (DSM) to access and monitor the inputs and outputs of the C Series Modules on your cRIO. To use NI Distributed System Manager, follow the steps below.
    1. Install Distributed System Manager
    2. If you don't already have NI-RIO IO Scan and System State Publisher installed on your cRIO, you will need to install them as features.
    3. Once you have Distributed System Manager installed, follow the Monitor CompactRIO System Resources and I/O With the Distributed System Manager article to monitor your CompactRIO system.
Each C Series I/O module interfaces with the FPGA. Therefore, NI-MAX is not able to determine which C Series modules are inserted into the cRIO chassis. Once you create a cRIO project, LabVIEW will download a personality to the FPGA that detects which modules are inserted in the cRIO chassis and you will have an opportunity to detect inserted modules to view in the project explorer.
A cRIO without NI-DAQmx capabilities will enumerate in MAX similar to the following image:
