Failed to Load Dynamic Library Error When Opening LabVIEW VI or EXE
Updated Mar 31, 2025
  • LabVIEW 2016 Full
  • LabVIEW Professional
  • LabVIEW Base
When trying to open a VI or run a LabVIEW built executable, LabVIEW displays the following error:
Failed to Load Dynamic Library Because of Missing External Symbols or Dependencies, or Because of an Invalid File Format
LabVIEW gives this error when a VI lacks the data necessary to open. The VI may have become corrupted and unrecoverable.
  • Try opening a backup copy of the VI
  • Try to open the file in other versions of LabVIEW or on another computer
  • Try to use another VI.
To prevent or mitigate this issue:
  • Make frequent backup copies of the VI
  • Save VIs in a local location instead of on a network
  • Uninstall and Reinstall LabVIEW.
If you receive this error when trying to deploy a built application (EXE file) on a target computer:
  • Make sure the correct LabVIEW Runtime Engine is installed.
  • If your application calls into any 3rd-party DLLs or libraries, make sure those libraries and any dependencies are installed in the correct location on the target PC.
  • In some cases, installing the LabVIEW development environment on the target computer may resolve this error.
This can also occur if conflicting changes are made to a body of code. For example, if 2 developers make independent edits to the same code and do not merge the changes, the conflicting changes can cause a VI to become corrupt. To prevent conflicting changes, make sure each developer only submits edits on the latest version of code. For more information, take a look at our White Paper on Software Configuration Management and LabVIEW .
