This behavior is a known bug in LabVIEW 2026 Q3 and is tracked under Bug ID 4068553.
This issue is planned to be resolved in the release of LabVIEW 2027 Q3.
In the meantime, you can resolve the issue in LabVIEW 2026 Q3 by applying the patched support VI provided below (Attachments section) or contacting NI Technical Support:
Step 1: Replace the Support VI
- Close all instances of LabVIEW 2026 Q3.
- Navigate to your LabVIEW installation directory:
<LabVIEW 2026>\vi.lib\SourceControl\support - Create a backup copy of the existing
SCCSup_Dynam 3ButtonDialog.vi (e.g., rename it to SCCSup_Dynam 3ButtonDialog_backup.vi). - Replace it with the patched
SCCSup_Dynam 3ButtonDialog.vi attached to this article.
Step 2: Unblock and Trust the Replaced VI
Because replacement files downloaded through a web browser or email client may be flagged as untrusted by LabVIEW security checks, the VI may display a broken Run arrow until trusted:
- Launch LabVIEW 2026 Q3 and open
SCCSup_Dynam 3ButtonDialog.vi directly from:
<LabVIEW 2026>\vi.lib\SourceControl\support - If the Run arrow appears broken, click the broken Run arrow or press Ctrl+L to open the Error List.
- If the error indicates the VI is located in an untrusted location:
- Click Manage Trusted Files (or go to View » Manage Trusted Files).
- Select
SCCSup_Dynam 3ButtonDialog.vi from the list. - Click Trust Selected File, then click Apply.
- Close and restart LabVIEW.
- Open your project, open a checked-in VI, and edit an object to verify that the Source Control checkout prompt appears.
