Prepare a Recovery Plan Before Applying an NI-PAL Update
Updated Nov 3, 2026
  • NI-PAL
I am planning to update NI-PAL version 26.3.1 and would like to know whether I can roll back to the previously installed version if the update causes issues. I need to understand what recovery options are available and whether NI-PAL includes a built-in rollback mechanism.
NI-PAL does not include a built-in rollback capability that automatically restores a previously installed version after an update.
If rollback capability is a requirement within an organization's change management process, preserve the system state before applying the update. This provides the most reliable recovery option if the update must be reversed.
Consider the following best practices before installing an NI-PAL update:
  1. Create a full system image of the computer.
  2. Create a virtual machine (VM) snapshot if the system is running in a virtualized environment.
  3. Use an organization-approved backup or imaging solution to capture the current system state.
  4. Validate that the backup or snapshot can be restored according to the organization's recovery procedures.
  5. Apply the NI-PAL update only after the backup or snapshot has been completed successfully.
If issues occur after the update, use the previously created system image, VM snapshot, or approved backup mechanism to restore the system to its earlier state.
