If the issue persists after disabling power management:
Verify Device Communication
- Disconnect and reconnect the Ethernet cable.
- Refresh NI MAX.
- Check whether the chassis appears under Devices and Interfaces.
- Run continuous ping tests to the chassis IP address and monitor for dropped packets.
Reset NI MAX Configuration
Corrupted NI MAX configuration data may occasionally contribute to device discovery issues.
- Close NI MAX.
- Reset the NI MAX configuration database.
- Restart the PC.
- Launch NI MAX and rediscover the chassis.
Review Windows Event Logs
Check Windows Event Viewer for events occurring at the time of the disconnection, including:
- Network adapter resets
- Link state changes
- Power management events
- Driver-related warnings or errors
Validate the Network Environment
- Test with a known-good Ethernet cable.
- Test using a different Ethernet port on the PC.
- Verify the latest network adapter drivers are installed.
- Test from an alternate PC when possible.
