SystemLink™ Base / Full / Pro Fails to Connect With VLM Server
Updated Nov 5, 2026
  • SystemLink
  • SystemLink Base
  • SystemLink Full
  • SystemLink Professional
Other
SystemLink™ Base / Full / Pro deploys to a WSL Linux Virtual Machine (VM) hosted on the Windows computer, and the NI License Manager (NILM) that needs to consume that license is also running inside that same WSL Linux VM.  The usual TCP communication ports (default 27000, 4637) used by the NI Volume License Manager (NI VLM) must be open between the host Windows computer and the WSL Linux VM running on it.  The host Windows computer treats the WSL Linux VM just like an external server on the network.
I have imported the *.lic file I got from NI into my NI Volume License Manager (NI VLM) and started the license server, but my SystemLink™ Base / Full / Pro fails to connect with VLM Server's license.
First create new firewall rules on the host Windows computer so that FlexLM can communicate between it and the WSL Linux VM that houses SystemLink™ Base / Full / Pro and NILM, then use the SystemLink Configuration Utility on the Windows computer to instruct SystemLink™ Base / Full / Pro to use the NI VLM license.
  1. Open a PowerShell console with Administrative privileges on the host Windows computer
  2. Issue the command to create a new firewall rule to allow FlexLM traffic on port 27000 to the Windows computer (from the WSL Linux VM)
    New-NetFirewallRule -DisplayName "FlexLM 27000 Any" -Direction Inbound -Protocol TCP -LocalPort 27000 -RemoteAddress Any -Profile Any -Action Allow
  3. Issue the command to create a new firewall rule to allow FlexLM traffic on port 4637 to the Windows computer (from the WSL Linux VM)
    New-NetFirewallRule -DisplayName "FlexLM 4637 Any" -Direction Inbound -Protocol TCP -LocalPort 4637 -RemoteAddress Any -Profile Any -Action Allow
  4. Look up the Computer Name from the NI Volume License Manager application
  5. Open the SystemLink Configuration Utility, choose the Licensing page at the lower left, select Volume License Manager as the Licensing type,
    then enter the VLM server hostname you found in the previous step, and finally click the Request license button
  6. Click the Apply button to apply these licensing selections and begin the restart of the SystemLink™ pods and services
  7. The process of stopping and restarting all the SystemLink™ pods and then checking out the VLM license will take several minutes, at least.
  8. While this process is ongoing, you can monitor the status of the SystemLink™ pods using the Status page of the SystemLink Configuration Utility
  9. The VLM license checkout can not proceed until the SystemLink™pods are fully restarted, which looks like this
  10. When the VLM license checkout is complete, this is how the Licensing page of the SystemLink Configuration Utility will appear
  11. When the VLM license checkout is complete, this is how the Licenses page in the SystemLink™ web user interface will appear
