VCOM Bus Monitor Does Not Display Array Signals Defined in ARXML
Updated Nov 2, 2026
  • Vehicle Communication Toolkit
When using the Vehicle Communication Toolkit (VCOM) with an ARXML-based signal database, array-based signals such as U8 arrays are not displayed in the Bus Monitor.
Other signals from the ARXML database may be available as expected, while signals defined using array data types are missing from the Bus Monitor.
The following behavior may be observed:
  • An ARXML database containing array signals is loaded into a project using the VCOM Custom Device.
  • Messages containing array data can be transmitted.
  • The corresponding array signals, for example U8 arrays, are not shown in the VCOM Bus Monitor.
The VCOM Bus Monitor currently does not support displaying array signals such as U8 arrays defined in ARXML. This is a known limitation of the current functionality.
