The PXIe-6594 module supports the following connector specifications, lane data rates, and transceiver requirements:
Connector Type:
- The PXIe-6594 uses a QSFP28-rate physical cage.
- PORT 0 and PORT 1 are documented as compliant with SFF-8436 for pinout and management interface purposes. This reference defines the interface layout and does not limit the module lane rates to 10 Gb/s.
Maximum Data Rate per Lane:
- Each QSFP port provides four transmit and four receive lanes, offering eight bidirectional GTY channels total across the two ports.
- The supported lane-rate range is 500 Mb/s to 28.2 Gb/s per lane.
Optical versus Electrical Data Rate Limits:
The documented specifications are correct and are not reversed:
- Electrical/Copper: Supports up to 28.2 Gb/s per lane.
- Optical: Supports up to 16.3 Gb/s per lane. The optical port supply is specified at 3.3 V ±5% with a maximum current of 1 A per port.
Optical Transceiver Compatibility:
- 100G QSFP28 Optical Transceivers (~25 Gb/s per lane): Not supported for 100G operation because 25 Gb/s per lane exceeds the 16.3 Gb/s-per-lane optical limit. These can only be considered if the transceiver supports operating modes at or below 16.3 Gb/s per lane and complies with the module's power specifications.
- 10 Gb/s per Lane Transceivers: Transceivers operating at 10 Gb/s per lane fall within the optical speed limit. Verify the following specifications in the manufacturer datasheet prior to selection:
- Maximum supply current does not exceed 1 A at 3.3 V.
- Uses a compatible QSFP/SFF-8436 management and control interface.
- Host electrical interface provides four transmit and four receive lanes.
- Internal CDR/retimer supports the target rate or can be bypassed/configured appropriately.
If the application design requires data rates exceeding 16.3 Gb/s per lane, use an electrical/copper connection instead of an optical transceiver.
