C-States Remain Active in Linux Even When Disabled in BIOS on Intel-Based PXI(e) Controllers
Updated Oct 30, 2026
  • PXI Controller
  • Linux
I disabled CPU C-States in the BIOS of my Intel-based PXI/PXIe controller, but Linux still appears to be using C-States.
After booting into Ubuntu, or another Linux distribution, I observe one or more of the following behaviors:
  • Running cpupower idle-info still shows idle states such as C1, C1E, C3, or C6.
  • CPU idle-state residency statistics indicate that the processor continues entering deeper C-States after disabling C-States in the BIOS.
  • My application exhibits increased timing variability, latency spikes, or execution-time jitter.
  • The BIOS setting to disable C-States appears to have no effect once Linux has booted.
This behavior is expected Linux behavior and is not indicative of a PXI controller hardware failure or BIOS defect.
Modern Linux distributions frequently use the intel_idle driver to manage CPU idle states on Intel processors. The intel_idle driver contains processor-specific idle-state information and may manage CPU idle states independently of the ACPI C-State information provided by the BIOS. As a result, disabling C-States in the BIOS may not prevent Linux from exposing or using deeper processor idle states.
To reduce or prevent the use of deeper C-States, use one of the following methods:
Force Linux to use acpi_idle
  1. Configure the kernel boot parameter: intel_idle.max_cstate=0
  2. Add the parameter to your bootloader configuration (for example, GRUB).
  3. Reboot the controller.
  4. Verify the active idle driver after reboot.
Disable C-States Directly in Linux
  1. View available idle states using: cpupower idle-info
  2. Review the idle-state entries located in: /sys/devices/system/cpu/cpu*/cpuidle
  3. Disable deeper idle states as required through the Linux cpuidle interface.
