LabVIEW does not provide native built-in VIs to generate QR codes. To generate QR codes programmatically, use one of the following approaches:
The QR Code Generator Toolkit by Lexcom Consultants Ltd is available through the NI Tools Network. It is implemented in LabVIEW G-code and can generate QR codes without requiring external DLLs or online services. It supports Numeric, Alphanumeric, Binary, and Kanji modes and can export to PNG or EPS format.
- Download and install the toolkit from the QR Code Generator Toolkit Download page.
- Open and explore the shipping examples located in the installation directory:
- 64-bit LabVIEW: C:\Program Files\National Instruments\LabVIEW <Version>\examples\Lexcom Consultants\Lexcom Consultants QR Code Generator Toolkit
- 32-bit LabVIEW: C:\Program Files (x86)\National Instruments\LabVIEW <Version>\examples\Lexcom Consultants\Lexcom Consultants QR Code Generator Toolkit
- Run Generate QR Code Modular Example.vi to test generating QR codes.
Option 2: Call Python QR Code Libraries Using the Python Node
You can generate QR codes by calling an external Python script using the native LabVIEW Python Node:
- Install the required Python packages by entering the following command in the command-line interface:
pip install qrcode pillow - Create a Python script using the
qrcode library to generate the QR code image. - Call the Python script from your LabVIEW block diagram using the Python Node.
