Slow Loading and Saving of DIAdem Data on a Network Drive
Updated Oct 27, 2026
  • DIAdem
When I load or save a TDM measurement from a network drive, DIAdem takes several minutes. The same operation completes normally with local files, and copying the files with Windows Explorer is fast. The delay may also appear when a script loads data and a REPORT layout. How can I improve performance?
Set DIAdem to load all measurement values when opening the data file.
1. Open Settings > DIAdem Settings.
2. Select NAVIGATOR > Loading Behavior.
3. Select Always load bulk data and click OK.
4. Reload the measurement files and repeat the loading, saving, or report workflow.
Keep the associated .tdx file accessible when loading a .tdm file.
Depending on its loading behavior, DIAdem can postpone reading measurement values until they are accessed or modified. Accessing these values later can introduce delays when the source is a network share. With immediate loading, the values are read into DIAdem's internal storage during the initial load.
This mode is suitable for workflows with frequent data access when execution speed matters more than a quick initial load. The initial load may take longer because all values are read immediately.
