Including NI Update Service in a Package-Based Deployment Installer
Updated Oct 27, 2026
  • TestStand
  • LabVIEW Package Builder
  • NI Package Builder
Package-based deployment installers can include NI Update Service (the ni-update-service package), which lets deployment targets check for and receive software updates for NI software and drivers. Most deployments do not include it unless the builder adds it manually. Legacy deployment installers cannot include Update Service.
This document describes when a builder might want to include it, and how to add it manually in LabVIEW, TestStand Deployment Utility, and NI Package Builder.
Before including NI Update Service in a deployment installer, consider the following:
  • Including Update Service increases the installer’s size.
  • Update Service may not be usable on deployment targets that have no internet access.
  • Depending on how the target is used (for example, a validated or locked-down system), easy patchability may not be desirable.
  • These steps apply to package-based deployments only.
LabVIEW (Package Build Specification)
  1. Right-click the package in the LabVIEW project and select Properties.
  2. On the Dependencies page of the Package Build Specification, deselect Automatically select dependencies.
Note: With this option cleared, LabVIEW no longer selects dependencies for you. You must manually select every other package the deployment needs, such as driver runtimes.
  1. Set the filter option to All visible packages.
  1. Find and select NI Update Service in the list of available packages.
4. Right-click the package in the LabVIEW project and select Build.
  1. For a package-based distribution, open the Dependencies dialog from the Package Distribution Options tab.
  1. Set the filter to All Visible Packages.
Note: TestStand has no equivalent of LabVIEW’s Automatically select dependencies option.
NI Package Builder
  1. Open the Add Dependencies dialog.
  1. On the Installed Packages tab, set the filter to Products Only. All Visible Packages also works, but the Products Only list is shorter, so Update Service is easier to find.
Other deployment builders
The steps for the other builders are expected to be similar: open the builder’s package dependencies, make the full package list visible, and select NI Update Service.
Verifying that Update Service is included
Build the installer, then open its pool directory and look for the ni-update-service package. This lets you check an installer without running it. No additional configuration is required for Update Service on the deployment target.
