MXI-Express BIOS Compatibility Software Cannot Find My Device
Updated Oct 21, 2026
  • MXI-Express BIOS Compatibility
I'm trying to use the MXI-Express BIOS Compatibility Software. When I select Scan for Devices it shows  "No relevant devices found."
For most MXI-Express systems, this is expected behavior. The MXI-Express BIOS Compatibility Software only needs to exist on the system, but does not need to be interacted with. You only need to use the "Scan for Devices" function when using a NI ExpressCard-8360 or NI PCIe-8398. All other cards are configured via the DIP switch located on the card.
See Using MXI-Express BIOS Connectivity Software for more information on how to configure your device.
