Why Can't PXI-5922 and PXIe-4464 Share the Same Reference Clock for Hardware Synchronization?
Updated Oct 21, 2026
  • PXI-5922
  • PXIe-4464
  • NI-DAQ™mx
  • NI-SCOPE
I am using a PXI-5922 and a PXIe-4464 in a PXIe-1083 chassis and need to synchronize data acquisition between the two modules. My application requires the devices to share a common reference clock and use PLL-based synchronization to achieve aligned measurements.
I found that the PXI-5922 uses PXI_CLK10, while the PXIe-4464 uses PXI_CLK100. I attempted to compensate for the timing differences using post-processing, but this approach is not acceptable for my application. I would like to know whether these devices can share the same reference clock and, if not, what synchronization method is recommended.
The PXI-5922 and PXIe-4464 cannot share the same reference clock because the devices operate on different chassis clock resources:
  • PXI-5922 uses PXI_CLK10.
  • PXIe-4464 uses PXI_CLK100.
Because of this architectural limitation, a common reference clock synchronization scheme is not supported between these two devices.
Instead, I can synchronize the acquisitions by configuring both devices to use the same Start Trigger while allowing each module to use its native reference clock.
Result
The PXIe-4464 and PXI-5922 can share the same trigger, but the PXIe-4464 must use PXI_CLK100 while the PXI-5922 must use PXI_CLK10. Because the PXIe-4464 introduces an AI Filter Delay on each channel, a timing offset may be observed between the two acquisitions
Result:
VI Example
An example VI demonstrating synchronization between NI-SCOPE and DAQ Analog Input devices was provided as a reference implementation.
Result:
Although the devices can share a start trigger, measurements from the PXIe-4464 may appear delayed because the module introduces an AI Filter Delay on each channel. This delay should be considered when comparing measurements acquired from both devices.
