How to Silently Install an NI Offline Installer (.ISO file)
Updated Oct 27, 2026
  • Package Manager
After downloading an NI offline installer (.ISO), you can perform a silent installation using several supported methods. This article outlines the most common approaches for silently installing NI software from an offline installer.
Before proceeding, ensure that you have administrative privileges on the target system. This prerequisite is required to successfully perform a silent installation.
Method 1: Automatically Mount the ISO Using PowerShell
This method fully automates the mounting, installation, and cleanup process through a PowerShell script.
Note: Make sure to replace C:\Path\To\NI_Installer.iso below with the actual path to your ISO file.
$isoPath = "C:\Path\To\NI_Installer.iso"
$mount = Mount-DiskImage -ImagePath $isoPath -PassThru
$drive = ($mount | Get-Volume).DriveLetter
$exe = "${drive}:\Install.exe"
$proc = Start-Process -FilePath $exe `
-ArgumentList "--quiet","--accept-eulas","--prevent-reboot" `
-Wait -NoNewWindow -PassThru
$exitCode = $proc.ExitCode
Dismount-DiskImage -ImagePath $isoPath
Write-Host "Exit code: $exitCode"
Method 2: Extract the ISO and Deploy the Files
For the initial setup, manually mount the ISO by right-clicking the file and selecting Mount. Once mounted, copy all contents of the installer to a new folder. You can then distribute the new folder to target systems and execute the installation silently. Follow the instructions below:
  1. Open Command Prompt or PowerShell as an administrator.
  2. Run the following commands and arguments:
    1. start "" /wait "path of install.exe" --quiet --accept-eulas --prevent-reboot
Method 3: Extract the ISO Using 7-Zip
If 7-Zip is available on the system, you can extract the ISO contents and run the installer directly from the extracted directory.
"C:\Program Files\7-Zip\7z.exe" x "C:\Path\To\NI_Installer.iso" -o"C:\Temp\NI_Extracted" -y
start "" /wait "C:\Temp\NI_Extracted\Install.exe" --quiet --accept-eulas --prevent-reboot
echo %errorlevel%
Older versions of NI Package Manager support different flags for unattended installations:
  • Before NIPM 20.7, the '--quiet' flag is not recognized. In these versions, use the '--passive' or '--progress-only' flags instead of '--quiet' to provide non-interactive installations.
  • Before NIPM 19.0, use the '\q' flag to start the non-interactive installation instead of '--quiet --accept-eulas --prevent-reboot'.
Note: Exit code -125071 indicates that the installation was completed successfully, but a system reboot is required.
