Should Windows 10 Pro (64-bit) Users Install the NI-PAL 2026 Q3 Security Update?
Updated Oct 29, 2026
The NI-PAL security update guidance identifies Windows 10 systems as potentially affected. However, Windows 10 Pro (64-bit) is not currently listed as a supported operating system on the NI-PAL 2026 Q3 download page.
Should users of Windows 10 Pro (64-bit) install the update?
Yes. Users of Windows 10 Pro (64-bit) should install the NI-PAL 2026 Q3 security update if their system contains an affected NI-PAL version.
The underlying vulnerability also affects Windows 10. The fact that Windows 10 Pro (64-bit) is not currently listed on the download page does not change the recommendation to install the patch.
For installation instructions and the latest guidance, see:
Required NI-PAL Security Update
Note: As of May 1, 2021, NI software no longer supports 32-bit Windows operating systems. For more information, see:
NI Support for Windows 7, Windows 8.1, Windows Server 2008 R2, Windows Server 2012 R2, and All 32-Bit Windows
