- Open the RF Signal Generator panel. This is where script generation is configured.
- Configure the panel for script-based generation. Script Trigger is used only in Script mode.
3. Create or load a script that contains a wait until scriptTriggerX statement. This is the line that pauses execution.
4. Open the panel’s Trigger settings and select trigger type from the dropdown menue. This is where you map Script Trigger input. For example, Digital Edge is selected in the picture below.
5. Assign the Script Trigger source, such as a PXI trigger line when Digital Edge or Digital Level is selected. For example, PXI_Trig0 is selected in the picture below.
6. Run the generator. The script starts and waits at the trigger line.
Send the trigger from the selected source. Generation continues when the trigger arrives.
