Verify NI-IMAQdx Compatibility Before Updating to NI-PAL 2026 Q3
Updated Oct 29, 2026
  • Camera
  • Vision Acquisition Software
  • NI-IMAQdx
  • NI-PAL
Use this procedure to verify that your NI Vision system meets the software requirements for updating to NI-PAL 2026 Q3 (26.5).
Before updating to NI-PAL 26.5, verify your installed versions of NI-IMAQdx, LabVIEW, the Microsoft .NET Framework, and the Windows operating system. Validating compatibility before applying the update helps prevent camera detection issues in NI Measurement & Automation Explorer (NI MAX) and LabVIEW.
This article is intended for users running NI Vision Acquisition Software with NI-IMAQdx-based cameras.
Before updating to NI-PAL 2026 Q3 (26.5), verify the NI-IMAQdx version, and Microsoft .NET Framework version installed on the system.
To identify installed NI software versions:
  1. Open NI MAX.
  2. Select My System.
  3. Expand Software.
  4. Locate NI-PAL and NI-IMAQdx.
  5. Select each component to view its installed version.
To verify the Windows Build and installed .NET Framework version, run the following PowerShell command:
$net = Get-ItemProperty 'HKLM:\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full'
".NET Framework $($net.Version) (Release $($net.Release))"
Example output:
.NET Framework 4.8.09032 (Release 533320)
Compare the installed software versions against the requirements below before updating to NI-PAL 26.5.
Windows 10
For systems running Windows 10, verify that the installed software versions meet all the requirements listed below before updating to NI-PAL 26.5. If any requirement is not met, updating NI-PAL may result in NI-IMAQdx compatibility issues that can affect camera detection in NI MAX or LabVIEW.
Windows 10 requirements NI-PAL 26.5
RequirementDetails
.NET FrameworkVersion 4.8 or later
NI-IMAQdx VersionNI-IMAQdx 20.0 or later
LabVIEW VersionLabVIEW 2017 or later
If the system does not meet all the requirements listed above, do not update NI-PAL to version 26.5.
Windows 11
For systems running Windows 11, verify that the installed NI software versions meet the requirements below before updating to NI-PAL 26.5.
Windows 11 requirements NI-PAL 26.5
RequirementDetails
LabVIEWVersion 2023 Q3 or later
If using a LabVIEW version earlier than LabVIEW 2023 Q3, review the Vision Acquisition Software Release Notes and verify that NI-IMAQdx 20.0 or later is compatible with the installed LabVIEW version before updating NI-PAL.
After completing this procedure, you will know whether the installed NI Vision software stack is compatible with NI-PAL 2026 Q3 (26.5) and whether the system can be safely updated.
Next Steps
