Error 263027 When Retrieving a cRIO Image in NI RAD
Updated Oct 21, 2026
  • Replication and Deployment Utility
  • System Configuration
  • NI CompactRIO
Other
  • OpenSSH
  • When I try to retrieve an application image from a NI CompactRIO (cRIO) controller running NI Linux Real-Time using NI Replication and Deployment Utility (RAD), the retrieval fails while RAD queries the software installed on the controller.
  • The following error message appears:
Application Image Retrieval Error:
nisyscfg.lvlib:Get Installed Components.vi:3430001<APPEND>
Complete call chain:
    rad_GetInstalledSoftware.vi
    rad_Retrieve Application Image From Target.vi
    Replication and Deployment Utility.vi - 263027
  • I can communicate with the controller in NI Measurement & Automation Explorer (NI MAX), but RAD cannot retrieve an application image from the controller.
One confirmed cause of this error is that the Windows user account running RAD has not yet accepted the SSH host key for the cRIO controller. During application image retrieval, RAD uses NI System Configuration to query the software installed on the controller.
Accept the controller's SSH host key through Windows OpenSSH from the same Windows user account that runs RAD, and then retry the application image retrieval.
Complete the following steps:
  1. Close RAD.
  2. Open Command Prompt or Windows PowerShell under the same Windows user account used to run RAD. Do not run the terminal under a different Windows user account.
  3. Run the following command, replacing <cRIO IP address> with the IP address of the cRIO controller: ssh admin@<cRIO IP address>
  4. If Windows displays a host-key prompt similar to the following, verify that the connection is being established with the intended controller. Then enter yes to add the controller's host key to the current Windows user's OpenSSH trust store:  Are you sure you want to continue connecting (yes/no/[fingerprint])?
  5. Sign in using the controller credentials.
  6. After the shell prompt appears, close the SSH session by running the following command: exit
  7. Reopen RAD and retry the application image retrieval.
    If the SSH Connection Is Refused
    Verify that the SSH service is available on the controller:
    If the Error Persists
    If accepting the SSH host key does not resolve the error, perform the following checks one at a time. After each check, repeat the SSH connection procedure described above and retry the application image retrieval in RAD.
    • If the cRIO controller was reformatted, replaced, or reconfigured, its SSH host key might have changed, refer to: Verifying SSH Host Keys. Remove the stored host key for the controller from the current Windows user's OpenSSH configuration by running the following command in Command Prompt or Windows PowerShell: ssh-keygen -R <cRIO IP address>
    • If the controller has multiple active Ethernet interfaces, confirm which IP address RAD is using. Temporarily disconnect any unused Ethernet interface or configure each active interface on a different subnet. Then verify that RAD is connecting to the intended controller IP address.
    • In NI MAX, expand Remote Systems, select the controller, and open the System Settings tab. Check Primary Disk Free Space and Primary Disk Capacity to verify that sufficient space is available to create the image.
      • RAD creates the application image on the controller before transferring the image to the host computer. The required free space can vary depending on the controller configuration and the software installed on the controller.
      • If the available space is insufficient, remove unnecessary files or unused software.
    Establish the initial SSH connection only through Windows Command Prompt or Windows PowerShell from the same Windows user account that runs RAD.
    PuTTY and other terminal clients can use a host-key trust store that is separate from the Windows OpenSSH known_hosts file. Establishing an SSH connection through one of these applications might therefore not add the controller's host key to the Windows OpenSSH trust store used by the RAD workflow.
